Running non-detergent oil in a small engine (or any 4 stroke engine) crankcase causes sludge to accumulate. Sludge buildup in turn shortens engine life.
A couple possible explanations for the confusion:
1 - Some small engine manufacturers recommend using straight weight detergent oil (eg. SAE 30) over multi-viscosity oils (like 10W-30). Reason: Viscosity index improver additives in multi-vis oils tend to break down under the high temperatures of small, air cooled engines resulting in reduction of the oil’s lubricating ability. Single weight oils do not experience this breakdown.
2 - Before dedicated “2 stroke” oils were developed, 2 stroke engine manufacturers recommended straight, non-detergent oil mixed with the fuel. This is because additives in detergent oil (metallic salts, etc) when burned leave conductive deposits on spark plug electrodes. And the deposits cause plugs to foul/misfire.
Bottom line: Forget the “experts” at the coffee shop…..follow the engine mfr’s oil recommendations!
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
