Re: farmall 100 missing spark
Posted by Janicholson on June 04, 2008 at 12:34:54 from (66.173.50.13):
In Reply to: Re: farmall 100 missing spark posted by CWB on June 04, 2008 at 10:57:03:
Remove the wire on the outside of the dist. Take a known good condenser, and jumper its lead to to that wire, and its body to ground. Then put a spark plug wire in the coil directly and put a spark plug in it with the body grounded. Turn on the ign and tap the end of the wire to ground. This is basically a "new" set of points and removes components from the system. If there is now spark coming from the coil, the issue is in the dist.
If not, the issue is with supply. JimN
