Re: Farmall H running problem
Posted by Slappy on June 04, 2008 at 14:19:08 from (143.88.85.88):
In Reply to: Farmall H running problem posted by Ty on June 04, 2008 at 13:39:13:
I could indeed be the governor. They are fairly simple disassemble and to trouble shoot. The spring might be weak, but it sounds to me like the problem may be elsewhere. I would check and repair or replace as needed, the bearing and/or the pins and weights. Most of the problems I've encountered has been related to loose and worn pins and pin weights.
Good Luck
