Pull the cap off and the coil wire from the cap. Turn on the switch and open and close the points by hand. Hold the coil wire close to the engine. If you get no spark from the coil wire and at the points also then you probably have bad or dirty points or the insulator in the side of the distributor is bad and shorted out
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
