Re: w-9 Timing Gears
Posted by David Novak on June 04, 2008 at 16:31:54 from (141.156.32.57):
In Reply to: Re: w-9 Timing Gears posted by Steven f/AZ on June 04, 2008 at 14:54:42:
I had thought of that but did not know if it would work. Thanks so much, David
