Re: Farmall Regular Rear End Input Shaft Leak
Posted by Loren in Iowa on June 04, 2008 at 18:27:32 from (207.177.2.187):
In Reply to: Re: Farmall Regular Rear End Input Shaft Leak posted by James Williams on June 04, 2008 at 18:17:13:
Jimmy-We have 85/140 wt. in it, now. I have straight 140 wt, to put in, if I change to a seal. Hadn't heard of using 180 wt., although we only use it in the summer, so it should work.-Loren
