Re: Anyone have a grapple on a 574 or equivelent?
Posted by Coax on June 04, 2008 at 20:54:12 from (24.113.61.135):
In Reply to: Anyone have a grapple on a 574 or equivelent? posted by Edpap on June 04, 2008 at 19:21:45:
Edpap said: (quoted from post at 19:21:45 06/04/08) so if my math is correct you want to pick up 1760 lbs on the front of a 574 tractor and drive to the woods and dump the rocks ?
I think you should think about about a bigger tractor. the front end will not hold up.
Good Luck Ed
abcrepairparts
I Have to agree with Ed, Your tractor is not big enough to handle the weight. Just because you can counterbalence the bucket, does NOT mean you can lift Buildings! Not a Good Idea.... :?
