Re: F12
Posted by Andy Motteberg on June 04, 2008 at 21:15:00 from (4.143.216.126):
In Reply to: F12 posted by Don Anderson on June 04, 2008 at 12:04:01:
If the engine turns over, make sure the carb is clean and properly adjusted, make sure all fuel lines are clean, make sure the fuel pump is working properly, make sure that you don't have old gasoline in the tank, if it is old, drain it and fill it with fresh gasoline, make sure the magneto has a good strong blue spark. Make sure the valves are all free and that you don't have any bent push rods. Also make sure the oil and filter are replaced. Be sure that there is coolant in the radiator too. Good luck with your F-12!
Andy.
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only ... [Read Article]
