Re: Setting farmall H Timing
Posted by Andy Motteberg on June 04, 2008 at 21:56:28 from (4.143.216.126):
In Reply to: Setting farmall H Timing posted by newhpuller on June 04, 2008 at 18:02:55:
Black plugs is not a timing issue, it may be running too rich, try leaning the carb adjustments a bit and see if that helps.
