Jeef said: (quoted from post at 22:04:36 06/04/08) I was under the understanding it was rated for 2000lbs on a loader?
I may have been misinformed.
It will pick it up easily, it just won't go anywhere cause the wheels slip.
Coax said: (quoted from post at 04:54:12 06/05/08)
Edpap said: (quoted from post at 19:21:45 06/04/08) so if my math is correct you want to pick up 1760 lbs on the front of a 574 tractor and drive to the woods and dump the rocks ?
I think you should think about about a bigger tractor. the front end will not hold up.
I Have to agree with Ed, Your tractor is not big enough to handle the weight. Just because you can counterbalence the bucket, does NOT mean you can lift Buildings! Not a Good Idea.... :?
Thats a MAX Load Rating. It will lift probably more than that but the front mounts will break off. Ive tried that and I've repaired the damage now. If You put a 1/2 barrel on the back with about 300-500# You should get some good use out fo the loader, but dont push your luck too far. Or it will get expensive. Good Luck!
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
