Posted by Steven f/AZ on June 05, 2008 at 07:32:24 from (216.67.213.217):
In Reply to: w-9 Timing Gears posted by David Novak on June 04, 2008 at 14:28:37:
I don't have my book with me and it's been a long time since I've looked at the arrangement of gears on a W-9...
What is the idler gear between?
If it is between the cam and crankshaft or the cam and magneto gears, then it must also be timed. You can make the marks just like I described above - two cogs on one of the gears and then the one cog that goes between them on the other gear.
If the idler is between something and the governor gear, doesn't need to be timed. The governor of course does not need to be timed.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
