It is 90% likely to not be stuck. It probably rusted to a smaller diameter, and twisted off. get a 5/16" course thread nut. Make a sheet metal bracket to hold the nut against the spot where the stud is broken, with a 5/16" hole in it over the hole in the nut. A magnet can be used to hold the sheet metal in place holding the nut. Use an arc welder to weld through the nut into the hole onto the broken bolt. (it may be necessary to have a helper turn on the welder while the rod is in the hole) The weld will not attach to the cold cast iron, it will weld the broken bolt to the nut (and shock treat it to heat). turn out the bolt and grin. JimN
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
