If you don't have access to a welder, try a left handed drill bit. Only time I ever tried using an easy-out on a manifold bolt all I succeeded in doing was having a piece of easy out stuck in the hole. Absolute worst scenario, as nothing will touch an easy out. Had a couple broken bolts come right out with a left handed drill bit.
If its really stuck, try drilling it out to where the drill bit is just touching the threads. You should then be able to take an awl or some other sharp, strong object and pick out the remaining slivers of metal.
Worse comes to worse, drill it out & put a helicoil in it. You can get helicoil kits at most good auto parts stores, just follow the directions on the kit. Only problem may be if the hole isn't deep enough to accomodate the helicoil tap.
Good luck, I hate it when things like that happen.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
