Re: F14 camshaft
Posted by scott rukke on June 05, 2008 at 21:15:00 from (67.183.230.71):
In Reply to: F14 camshaft posted by Doug Steinbach on June 05, 2008 at 19:03:32:
Did you mic them? MAy want to check the clearance on them. I assume you lubed them up with pre-lube. Not sure if the 14 is the same as the 20 but there are keeper screws on the back of the block on the 20. Sounds dumb but I made that mistake. Make sure they are all the way out.
