Re: H Shifter Stuck
Posted by mkirsch on June 06, 2008 at 05:24:20 from (64.80.110.50):
In Reply to: H Shifter Stuck posted by Big Red Man on June 05, 2008 at 20:25:19:
Once you get the shifter out, you may want to have a welder build up the ball on the end a little bit, and grind it down to its original size/shape so it fits in the slot better and doesn't slip out again.
Otherwise, you just have to be VERY careful shifting the tractor.
For the other guy's starter problem, you generally just need to put the tractor in 5th and rock it back and forth a little to get the starter to pop free. The whole thing with loosening the bolts is overkill. You can also get the drive end of the starter rebuilt or replaced at a starter shop for a reasonable price, and never have to deal with the problem again.
