Re: M running problem
Posted by Janicholson on June 06, 2008 at 07:23:47 from (66.173.50.16):
In Reply to: M running problem posted by bill 55 on June 05, 2008 at 19:21:36:
Three steps to better.
First try adjusting the load screw on the front bottom of the carb outward 1/2 turn at a time. After two full turns, if it is no better, put it back.
Next try the fuel floe test. If it has a drain on the bottom of the carb, try draining a stream of gas out of the carb into a clean can. it should run a stream 1/8" thick for more than a minute. If not there is a restriction in the fuel supply Screen at the carb, sediment bowl, or tank inlet.
If these all are OK, try an electrical tuneup. Plugs, points, condenser timing and checks for distributor shaft wear. JimN
