Re: Fuel Tank 140/Super A
Posted by Hugh MacKay on June 06, 2008 at 13:38:03 from (209.226.106.166):
In Reply to: Fuel Tank 140/Super A posted by Vacherie on June 06, 2008 at 06:11:41:
Vacherie: I went out to shop with SA and 140 side by side, went over them with a mearuring device, and the only difference I can see is length of back tank supports that attach it to the touch control unit. 130 is same as 140, and of course this is to accomodate higher radiator in all tractors factory equipped with C-123 engine.
Another thing I noticed last winter when I had my Super A dismantled for painting, serial number 336977 and already they had the same two position front fuel tank support as SA1, 100, 130 and 140. I know this tractor is all factory, so IH were getting ready for the change to SA1 as early as mid 53. I'd be almost certain the actual tank is the same.
