Re: carb kit
Posted by CNKS on June 06, 2008 at 14:10:06 from (216.144.104.128):
In Reply to: carb kit posted by poorfarmall 1 on June 06, 2008 at 10:47:11:
Float is usually measured with the throttle body upside down. Usually roughly horizontal. If you adjusted it horizontal with the throttle body right side up, the needle is in the closed position.
