Re: H Farmall timing gear
Posted by El Toro on June 07, 2008 at 03:36:51 from (64.12.116.73):
In Reply to: H Farmall timing gear posted by Bob And on June 06, 2008 at 18:05:27:
You will probably have to pull the camshaft and have the old gear pressed off & have your new gear pressed on. Hal
