Re: Configuring Lift Arms on homebuilt 3-pt for H
Posted by Dave in CT on June 07, 2008 at 04:15:18 from (69.183.14.195):
In Reply to: Configuring Lift Arms on homebuilt 3-pt for H posted by Dave in Connecticut on June 05, 2008 at 09:39:29:
I"m posting a reply to my own question as this may help someone. I opened up the holes in the lift arms (lower arms) that the frame mount pins go through to allow a little play, side-to-side. I also opened up the holes that the implement pins go through at the other end. The opening-up I had to do was very slight but now I can angle out the lift arms enough to get that 26"-30" spread that I need to mount the implements. I will get the setup right with ball ends at the end of the arms when I have the time.
