Re: 656 hydro
Posted by Allan In NE on June 07, 2008 at 06:04:28 from (148.78.243.24):
In Reply to: Re: 656 hydro posted by IaGary on June 07, 2008 at 05:37:36:
You nailed it.
They don't oil without pressure and those 18 little brass pistons (nine in each motor) are running dry against the steel swish plates.
The slip plates, which are fitted at the heads of the pistons, just simply cook themselves to death due to the instant friction.
Add to that, that the 656 used an "iffy" slip plate material anyway and it just makes for an expensive situation all the way around. :>(
Last I heard, those pistons alone were $100 apiece and that was 2 or 3 years ago.
Allan
