HOTDIGGIDYDOG!
Posted by Cub n M in OR on June 07, 2008 at 07:14:19 from (4.178.177.130):
After dinner last night I went out to the shop to putter around on this manifold replacement on my M. I applied several of the pieces of advice I was given here on removing that broken manifold stud.
1. Ground a flat spot on the end w/ a die grinder.
2. Found center and gave it a few solid wacks w/ a punch.
3. Got er good and hot with the acetylene torch.
4. Melted some candle wax on the hot area, I could actually see the wax being wicked into the threads.
5. Let it cool down while I rebuilt the carburator.
6. Drilled out the center w/ a 1/8 bit, then a 1/4 bit.
I think, just as the 1/4 bit was cutting through the back of the stud, it grabbed and gave er a 1/4 turn.
7. Put one of my old easy outs in the newly installed hole, and spun er out!
I can't really give much credit to the easy out(I've broken as many of them as anyone has) but it was just enough to pull er out.
Thanks a bunch for all the help fellas!
Ben
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
