You risk throwing a rod out the side of the block running it with a knock, assuming it is rod bearings. Considering you need the tractor to finish your hay, I would drop the pan and check the rod bearings. Inspect for visible wear and if they look ok to the naked eye, check the bearing clearance with plastigauge. A new set of rod bearings may be all you need to get you by until you are able to go through the engine more throughly.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
