Re: Farmall M with stuck motor
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by p on March 13, 2000 at 15:07:20 from (12.33.190.5):
In Reply to: Farmall M with stuck motor posted by Venda2 on March 13, 2000 at 14:44:03:
are you sure the starter is not wedged into the flywheel. I would pull off the starter and make sure it is free and then see if a big screwdriver will turn over the motor a bit(if you have a hand crank use it instead)
Post A Followup
: Re: Re: Farmall M with stuck motor
