Posted by Owen Aaland on June 07, 2008 at 14:05:40 from (65.165.246.71):
In Reply to: 656 hydro posted by calffeeder on June 06, 2008 at 18:55:14:
The real problem comes from the hydro motor swash plate is always set at an angle so when you try to move it it functions as a pump but the pump swash plates are most likely in the no pump flow position so as the motor turns it destroys the pivoting brass heads on the pistons. If you take it apart you will most likely find scored plates and the heads pulled off the motor pistons.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
