Some type of "snake oil" MAY help. However, if it really is an excessive "diesel knocK" caused by a sticky injector, or one with a bad tip, you may need to have the injectors checked, and cleaned and repaired as needed. While this won't be CHEAP, it's better than breaking a piston or doing other damage to the engine by continuing to run it.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
