F-14 brake cover removal
Posted by tractor Hank on June 07, 2008 at 19:45:25 from (24.124.104.36):
My right brake is leaking some oil and it needs adjusting and I also notice a rusted out hole in the bottom. I removed the 2 bolts holding the cover over the brake drum but can't get the cover off. Is there a trick to getting it off without destroying it. I will see if I can repair the hole or if someone has a good undented cover I would be interested in buying it. I am also looking for a good seat with working spring - not that it helps much when your driving it. Thanks, Hank 785-748-0061
