Re: 22-36 info requested
Posted by Ron Taylor on June 07, 2008 at 20:25:58 from (70.57.206.47):
In Reply to: 22-36 info requested posted by Kevin LA-CA on June 07, 2008 at 18:44:36:
If you crawl underneath just behind where the wishbone connects to the belly you'll find the casting date.Then look behind the manifold on the block you'll find another casting date.The 2 won't be the same but should be within a week or so of eachother.If there's a considerable span it means that probably the engine has been changed at some time.
