Re: Hydraulic system on 58 340 utility
Posted by PaulW_NJ on June 08, 2008 at 05:42:18 from (72.76.239.189):
In Reply to: Re: Hydraulic system on 58 340 utility posted by Hugh MacKay on June 08, 2008 at 04:53:28:
third party image
Here's what Hugh is referring to. The block with the hydraulic hoses running to the FastHitch cylinder is the check valve. Rebuilding the check valve is a simple fix. There's an Oring in there that can be replaced. That, however, may be the least of your worries, as all it does is keep the hitch from leaking down. Remove the check valve, and any lines connected to it for now. Connect the two lines coming toward the rear of the tractor from the valve under the dash and under the seat, to the hitch directly, and see what you've got when you move the control. A picture of your set up would help.
