Steven: Way back when A and Super A were relatively new, and NH 60 series and IH 46 balers were new, I had a neighbor with a Super A that wanted a new baler. He figured a new baler would speed up his loose hay operstion, and he didn't want a baler with engine, as he plan on a larger tractor as finances permitted.
He tried 4 balers on demonstration IH 46, MF forget the number, and NH S-69 and NH forget this model also but the smallest model with standard size bale. He couldn't run the IH or MF. The S-69 operated easiest on PTO, but he felt the lighter NH would be better on hills even though it ran a bit harder on PTO. I asked the NH dealer why, as we had an S-69. We decided the difference had to be the fact S-69 had it's plunger mounted on sealed bearing rollers. Anyway, he went on to bale about 6,000 bales yearly with Super A for three years, then he added a new David Brown 990 tractor. He then relagated the SA to mowing and raking.
I saw this as an IH mistake back then. Had the SA been able to run the 46, he would have also bought a 50 hp IH tractor. Just part of the evolution. I ocasionally used my Farmall 130 on our S-69 with thrower and pulling wagon on level ground. In the mid 60s I started haylage with Farmall 560D on NH S-717, 300 pulling wagons and Cockshutt 540 on blower. Almost daily I had material that got too dry for haylage. I couldn't take my crew off haylage to bale up this bit of too dry material. Between milkings, I'd turn it with rake to get bottom dry, then bale it with 130. Usually it never amounted to more than 100 bales, often in corners, and I told my haylage crew not to spend time on short windrows.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
