Have you checked the compression? The engine may simply be worn out and can't develop enough power to move even itself around.
A governor will TRY to maintain RPM, but if the power requirements exceed the power output of the engine, RPMs will drop. Going up a slope at an idle, you probably won't be able to detect the governor working. Drop the plow into the ground as you're traveling along at wide-open throttle in 2nd, you'll hear the tractor "hunker down" and "grunt" as the governor opens the throttle in response to the load. RPMs will drop slightly under any load, as governors are not that accurate.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
