Re: 806 with minor knock- OK to run for a while?
Posted by Hugh MacKay on June 08, 2008 at 05:58:51 from (216.208.58.140):
In Reply to: 806 with minor knock- OK to run for a while? posted by ironhoarder on June 07, 2008 at 07:17:23:
ironhoarder: Don't run it, don't even start it up until you get to bottom of problem. I don't know that 806 was ever prone to this problem, but the smaller 706 could break sleeves around the top. It would start off as a minor knock, that was the warning to shut it down.
The minor knock was sleeve moving up and down in the block, next move was piston sucking sleeve down with it, now the problem occurs when piston comes back up, things jamb up a bit when piston comes up.
I had this happen with my 560 with 282 diesel, same engine as 706. Tractor was on blower at silo, a young lad was changing wagons, 560 still running. He heard the knock, rather than shut it down he ran for help. When he got back with help, there were parts of two pistons plus parts of block scattered across the barnyard. KNOCKS are a warning, don't ignor them.
