Re: H will not stay running
Posted by El Toro on June 08, 2008 at 06:41:10 from (64.12.116.73):
In Reply to: H will not stay running posted by j3jackson on June 08, 2008 at 04:38:23:
The bottom screw is where to enrich the fuel mixture for power. You probably have fuel blockage somewhere. Pull the gas line at the carb. and see if there's a full flow of gas. Catch the gas in a clean container. If the flow is good pull that tube fitting and check that screen that's been suggested. If it is clean you probably need to clean the carburetor thoroughly.
The coil can cause the engine to quit that's been suggested, but you need to check for fire to the plugs asap before the coil cools. Hal
