H won't shift
Posted by fredmich on June 08, 2008 at 08:07:26 from (64.12.116.73):
Backed the H out of the shed to do some work with it and now its stuck in two gears at the same time unless the stick is in the nuetral position which puts it in high gear! Shifter is real sloppy. Don't know what to search for and looking for some help. Thanks...Fred
