Re: IH2400 backhoe/loader pump
Posted by jwal10 on June 08, 2008 at 16:50:43 from (71.215.149.100):
In Reply to: IH2400 backhoe/loader pump posted by danielm on June 08, 2008 at 08:00:00:
Is there a spin on filter up on the backhoe or on the loader frame, it might be plugged? My 2400 is the same as my 454 except it has the heavy front grill, The Hydro transmission and several other small differences. It originally had a front broom on it that I removed so didn't have any extra or oversize pump to run that. I have seen front pumps mounted as well as bigger side pumps. I have seen the bypass springs break and hang up and bypass oil. Does the tractor run warmer than before from pumping a lot of oil? Does the engine labor at medium rpm?....James
