How is the battery??? Check batt, voltage while cranking. If voltage is "good" check voltage at the coil terminal which comes from the ignition switch. If this voltage is "battery voltage" while cranking, suspect trouble in the points/condenser area. If voltage is low, check all connections in the primary ignition system---including the switch itself. You will be looking for a high resistance in the primary circuit. Don't overlook wire terminations--pull on them to check.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
