Re: Question for Jim N.
Posted by Janicholson on June 08, 2008 at 17:43:47 from (64.83.197.176):
In Reply to: Question for Jim N. posted by Dr. Bert on June 08, 2008 at 08:23:05:
cutouts do work with only one issue. That is you will not have regulation to your battery.
Why not use a VR for the A tupe setup and be done.
If it has a four position charge/light switch, that has a good resistor for low charge, do that, no issue. JimN
