Yes, they are the same. I have also noticed that an aftermaket kit may, or may not, have a seat with a different height than an original IH seat. What this means is, you may not get optimum results from your float setting if you set at factory specs with aftermarket kit. The usual problem is flooding and/or running rich. Cure: Set initial setting at just under 1/8" higher, which will keep fuel level in bowl lower and prevent flooding. mike
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
