Posted by Dave in CT on June 08, 2008 at 20:56:06 from (69.182.66.247):
In Reply to: h posted by dick orr on June 08, 2008 at 17:24:17:
I had an H with a bad coil that would quit and not start when it got hot. Do the coil check when it's hot - you may want to confirm this because it's been a while. I think you pull the center wire from the distributor cap (the one coming from the coil) and hold it using some thing _really_ insulated (like insulated pliers held with a heavy rubber gloved hand) about 1/8" to 1/4" inch away from a bare spot on the engine (be careful of oil and gas) and turn the engine over just a bit. If the spark you see is whitish-blue, your coil is good. If it's yellowish, the coil is bad.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
