Re: Configuring Lift Arms on homebuilt 3-pt for H
Posted by Dave in CT on June 08, 2008 at 21:03:14 from (69.182.66.247):
In Reply to: Configuring Lift Arms on homebuilt 3-pt for H posted by Dave in Connecticut on June 05, 2008 at 09:39:29:
Just another follow-up. The 3-pt was used to wield a bush-hog today to clear a small sloped field. Without the ball-socket ends on the trailing ends of the lift arms, mounting the bush-hog was a _little_ troublesome but nothing we couldn"t overcome in a few minutes. The hitch did it"s job well with just those simple holes. I"ll be putting the proper ends on just as soon as I can afford it.
