Re: newbie, Please help!
Posted by Baelee05 on June 09, 2008 at 03:55:44 from (69.19.14.15):
In Reply to: Re: newbie, Please help! posted by millerbarn4 on June 09, 2008 at 02:56:03:
The last thing you would do is to paint it. Not the first. Is the engine free? Can you turn if over with a crank. If the engine is free it might not take a whole lot to get it running. Do you plan on tackling the mechanical work yourself if the engine needs opened up? If you have no mechanical knowhow you might want to look for someone to help you who knows his way around an engine. The guys on here can talk you through a lot so whichever way you decide to go it will be okay. The first thing you need to do is find a suitable place to work on it and then determine the conditon of the engine. As I say, if the engine is free it might not take much to get it running. If the engine seems to want to turn don't turn it too much in case you have some stuck valves. If engine is free I would pull the head and inspect the valves. Real good chance they are stuck after sitting that long. As far as what it is worth in restored condition it depends some on the quality of the restoration. In any case pretty nicely restored late model F-20's can be bought for $2000 to $2500. You will very likely end up with more money in the tractor than it will ever be worth. If it were my dad's tractor I wouldn't care what it was worth or what I spent on it as long as it was mine. I know. I have my dad's 1962 JD 4010 which I have well over $10,000 in and it is worth about $7000. It's really nice and it was my dad's so it is priceless to me. Good luck. Let us know if we can help.
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
