Re: Remove a steering wheel on a Farmall H
Posted by HENRY E NC on June 09, 2008 at 06:58:57 from (216.119.6.170):
In Reply to: Remove a steering wheel on a Farmall H posted by mgolson on June 09, 2008 at 06:55:14:
Had same problem with M. I just put a cut in it all the way to the shaft and them spread it with a chisel. Came right off Nuff said Henry
