Re: Remove a steering wheel on a Farmall H
Posted by RustyFarmall on June 09, 2008 at 07:01:41 from (209.152.78.71):
In Reply to: Remove a steering wheel on a Farmall H posted by mgolson on June 09, 2008 at 06:55:14:
Sounds like you have already tried the normal tricks. The heat should have done it, but maybe you need to heat it up again, let it cool just a bit, spray it liberally with penetrating oil, then just walk away for about 20 minutes. Try the puller again. If it still won't move, you may need to split the hub.
