1974 Farmall 140 Need advice on carburetor
Posted by Randy Dragoo on June 09, 2008 at 07:47:18 from (208.127.203.115):
I've rebuilt my carb, and it wasn't succesful. I could see the top was warped when I reassembled it and now the idle mixture screw isn't metering correctly. I can turn it all the way in and the tractor keeps running. Time to replace it. It must have an internal leak. Are those replacement carbs you see new on ebay from some of the tractor supply guys a good quality? I see some of the replacement carbs have an extra screw on top to prevent the warping that mine had. I don't want to end up with something made in china.
