Re: Plow Bottoms
Posted by mkirsch on June 09, 2008 at 10:53:47 from (64.80.108.52):
In Reply to: Plow Bottoms posted by Chris450 on June 09, 2008 at 07:48:01:
Unless the plow frame is bent, any point on one bottom will be exactly the same distance away from the exact same point on the next bottom.
You can measure from the tip of the point to the tip of the next point, from landside to landside, from moldboard edge to moldboard edge, even from bolt to bolt. They'll be exactly 14" apart, measured straight across.
An easy way to do it is to take a framing square and lay it against the front bottom's landside so the L goes back and to the left, under the second bottom. You can read the measurement right off the square itself.
Just remember to read from the correct side of the square, or you'll end up thinking you have a 2" wider plow than you really do.
