Re: front wheels 44' H
Posted by Andrew Kappers on June 09, 2008 at 14:08:06 from (207.109.213.2):
In Reply to: front wheels 44' H posted by ryanroth on June 09, 2008 at 08:30:47:
You can get sets through case ih that have the seals, bearings, and gaskets all in one kit. What ive done to get the tire and rim off is run one tire up on a tire changing ramp. Do the one side and then do the other. Ive tried boards but i think it is a little safer having the ramps. Just make sure you put the tractor in gear and set the brakes to prevent it front from rolling on you.
