Re: Your leg will toughen up
Posted by Hugh MacKay on June 09, 2008 at 18:02:44 from (209.226.247.110):
In Reply to: Plumbing loader on 300 Farmall posted by Matt Compton on June 09, 2008 at 16:28:15:
Matt: I don't know what your comparing 300 clutch to, it's definitely not the easiest clutch to push down. Your left leg will toughen up, once you get that loader mounted.
