Re: Delco alternator charging then not?
Posted by Janicholson on June 09, 2008 at 18:57:14 from (66.173.50.61):
In Reply to: Delco alternator charging then not? posted by Andrew Z on June 09, 2008 at 17:17:38:
If the ground was bad it would not charge when it finally does. The regulator is probably bad. Why not swap the regulator for a three wire setup and rock on. JimN
