Re: H belt pulley oil capacity
Posted by BEL@IN on June 10, 2008 at 03:37:03 from (76.208.27.12):
In Reply to: H belt pulley oil capacity posted by joho on June 10, 2008 at 02:08:51:
It`s automatically filled from the trans. A quart or so if you wish on initial installation.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
