Re: IHC 766 Auxillary Valves Problem
Posted by Allan In NE on June 10, 2008 at 04:28:04 from (148.78.243.24):
In Reply to: IHC 766 Auxillary Valves Problem posted by TWilliams on June 09, 2008 at 08:20:31:
Do you have a HEAVY load that you could hook the 3-point to? A HEAVY tractor that you could back up to and try to lift the front end off the ground?
That will tell you wheather it's a pump pressure problem or a remote problem. Did you use a thick enough o-ring? New pump or used?
Are you getting those hydraulic lines inserted correctly?
Allan
